  3. save expression to file in ocean-xl
  • Views 15030
Karev11
Karev11 over 8 years ago
It seems the ocean script generated from ADEXL is able to cover all functionalities from the GUI.  However, there's one thing I have yet figured out and wonder if anyone can kindly offer some help.
If my simulation output expression is "vb_value", and swept variables are vdd (0.9V, 1V), corners (tt,ss,ff), temperature (0c, 100c), after ADEXL run, a tabulated vb_value results will be generated, with flexibility depending on "detail" or "detail-transpose", and the GUI allows to export the data to .csv file.
Now with ocean run, I wonder what will be the code to save the "vb_value" to a file, with format as below:
0.9V, tt, 0c  100mV
0.9V, tt, 100c  130mV
1V, ff, 100c  150mV
thanks!
Kevin
    Kevin,
    Do you just want ocnxlExportOutputView() ?
