  3. MDL: create a new waveform and save it into a wavefile
  • Views 15669
PatrikOsgnach
PatrikOsgnach over 8 years ago
I have this MDL file:
alias measurement mdltest {
run tran
print fmt("%g %g\n", xval(voutp), yval(voutp)) addto="sample.txt"
export real divided = V(voutp) / V(voutn)
run mdltest
and I run it with this command:
spectre =mdl main.mdl input.scs
During the simulation, a sample.txt file is created and the X and Y values of the signal are periodically written to it, as expected (it is important that I do not have to wait for the simulation to end).
I would expect the wave file, called mdltest.meas_tran (in this context), to contain a signal called "divided" and this signal should be the ratio of voutp and voutn at every time step of this transient simulation.
Instead, I have a signal which has only a single point of data. Why is this happening? The reference manual is not very clear on how to generate and plot a new signal from an expression.
Thank you and best regards,
Patrik
    Patrik,
    I'm not sure this is possible (from a quick check). I may be wrong though and I didn't do much experimentation, so I suggest you contact customer support as then it can be looked into in more detail and an enhancement CCR filed if it's not currently possible.
