  3. RelXpert Error with intermediate file input.p1
  • Views 14857
PatriciaG
PatriciaG over 8 years ago
Hello
I am trying to run RelXpert for the first time and I get the following error in the rxprofile.log file :
* Netlist file: profile.cfg
* Starting time: Thu Sep 14 16:37:56 2017
* Command Line Input: <server>/cadence/MMSIM141/tools.lnx86/relxpert/bin/64bit/rxprofile -ade -raw ../psf -log ../psf/rxprofile.log -out ../psf/.rxprofileMessages.out -spectre_args +escchars -format psfxl +lqtimeout 900 -maxw 5 -maxn 5
rxprofile starts: ......
Warning(RELXP-351): RelXpert statement '.age' in netlist will be ignored, 'use the age value set in the agepoint'.
=================================AGEPOINT: 2y================================
executing "relxpert -pre -profile 1 -agevalue 6.3072e+07 -sp -pre input.scs input.p1>temp.log "...
Error(RELXP-186): The RelXpert simulator failed to perform 'relxpert -pre -profile 1 -agevalue 6.3072e+07 -sp -pre input.scs input.p1>temp.log '. Check the profile option '' before running rxprofile again. Refer to the rxprofile.log file or the RelXpert documentation for more information.
rxprofile failed!(exit status 1)
When checking the temp.log file the Error is:
Error found by spectre during circuit read-in.
ERROR (SFE-874): "input.p1" 95: Unexpected string value "/".
ERROR (SFE-874): "input.p1" 7454: Unexpected string value "dnoin_mc".
Line 95 in input.p1 is
and line 7454 in input.p1 is:
+ dnoin_mc=0
Do you guys have any suggestion to fix the error?
Thanks!
Patricia
    Pretty hard to debug with just two lines of some of the intermediate files. I suggest you contact customer support.
