  3. Passing different CDF parameters values to instance arr...
  • Views 16390
Passing different CDF parameters values to instance arrays
pacikk
pacikk over 8 years ago
I'm trying to pass different transistor lengths/widths to an array of nfet devices MN0<2:0>. I tried passing "[100n 200n 300n]" in the length field of the nfet property window as suggested here: https://community.cadence.com/cadence_technology_forums/f/38/t/20875
but Spectre returns a warning: Invalid value '[100n200n300n]' of type `scalar string' encountered. Expected value is of type `double' and the wrong W/L values are used.
Is there a way of achieving this?
Patrick
    Hi Patrick
    (by the way, you can also get through to the official support via http://support.cadence.com )
    This is not possible. Iterated instances have to have identical parameters. You'd have to expand out the devices to separate physical instances to achieve this.
  • pacikk
    Thanks Andrew!
