  3. unable to load .sdb file
  • Views 17708
syafiq
syafiq over 8 years ago
I've got one weird issue with cadence. I am in the ADE-XL environment. When I try to load the corner setup by clicking on 'Click to add corners', Load Corners GUI shows up.
However, it won't show any folder or sub-folder where the .sdb file is located (please refer to the snapshot in the attachment).  Any idea how to fix this issue?
I am using IC6.1.4.
Syafiq
    What filesystem is the folder? Is it better if you run "virtuoso -64"? There's an issue with some of the newer file systems which support large numbers of files (64 bit inodes) which don't then work in 32-bit executables - it might be that (although I'd have expected a bunch of other things to not work if that was the case).
  • syafiq
    Hello Andrew,
    I have checked using df -T <folder>. and it is nfs type.
    May I know in which step should I run "virtuoso -64"?
    Syafiq
    Hi Syafiq,
    I think you'd need to know more about what file system it is on the filer, rather than just it being "nfs" (that's the protocol via which it is shared, not the underlying file system). I must admit I don't know how you find that out for a remote file system (without doing some deeper research).
    I was just suggesting seeing if starting Virtuoso by typing "virtuoso -64" rather than "virtuoso" (I assume that's how you start Virtuoso from the command line?) fixes the problem - that would give a fairly strong clue that it's down to large file system support.
