  3. Invalid probe for a .measure statement where node also exist...
  • Views 14931
Invalid probe for a .measure statement where node also exist as port in one hierarchy above
roopakvasa
roopakvasa over 8 years ago
Hello All,
Consider the following node in a .measure statement
V(segio.segio0.controls.xcontrols_opt/RDWEN_T)
Now when
1) RDWEN_T is signal above statement works.
2) when RDWEN_T is port is gives invalide probe. when I checked out in waveform viewever this port is there one hierarchy above(same same).
So what option I should use to make simulator understand ?
Thanks.
Using spectre-xps simulator
    It’s not entirely clear what you mean about when it’s a signal and when it’s a port. I would expect the syntax to be:
    V(segio.segio0.controls.xcontrols_opt.RDWEN_T)
    i.e. a dot rather than a slash. This should give the voltage on the node RDWEN_T within that specific subckt instance, whether it’s an internal signal or it’s one of the I/O of the subckt.
    Does that answer your question? If not, you’re going to have to explain it a bit more clearly.
