  3. ERROR (VACOMP-1008)
  • Views 17920
ERROR (VACOMP-1008)
irenemmartin
irenemmartin over 8 years ago
Hi!
During simulations I have found these two errors in the log file (I'm trying to simulate a verilog-A component):
ERROR (VACOMP-1008): Cannot compile ahdlcmi module library. Check the log file input.ahdlSimDB//47c64761172b7ee38fd8b848ec102865.resistor_v1.ahdlcmi/Linux-64//..//ahdlcmi.out for details. Contact your Cadence Customer Support representative with the netlist, log files, behavioral model files, and any other information that can help identify the problem.
ERROR (SFE-91): Error when elaborating the instance resistor_v1. Simulation should be terminated.
Also there are two warnings:
WARNING (VACOMP-2435): The environment variable CDS_AHDLCMI_ENABLE is no longer supported. Therefore, the simulator will use the default compiled C code flow.
(This one is because I have set CDS_AHDLCMI_ENABLE as "export CDS_AHDLCMI_ENABLE=NO"... I have read on Internet that maybe this sentence could solve the problem...Either way the simulation doesn't work)
WARNING (VACOMP-2397): Compilation failed when using pipe build. Bytecode flow will be used for encrypted VerilogA, and normal file compilation will be used for unencrypted VerilogA.
I attach the ahdlcmi.out file. In addition, I provide the following data:
  • Spectre -W: sub-version 15.1.0.627.isr12
  • Uname -a: Linux simulation-server 4.2.0-42-generic #49-Ubuntu SMP Tue Jun 28 21:26:26 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
The command cat /etc/redhat-release gives an error (No such file or directory)
Can anybody help me to solve this problem? Any idea? I would very much appreciate.
Best regards,
Irene
Fullscreen 6661.ahdlcmi.txt Download
ahdlcmicompile: Compiling ahdlcmi in input.ahdlSimDB//47c64761172b7ee38fd8b848ec102865.resistor_v1.ahdlcmi/Linux-64/ for Linux-64 with optimize using gcc on Wed Oct 18 14:59:31 CEST 2017 [5.0]
ahdlcmicompile: Generating makefile
PATH:  /opt/cadence/installs/MMSIM151/tools.lnx86/cdsgcc/gcc/4.1-x86_64/install/bin:/opt/cadence/installs/MMSIM151/bin:/opt/cadence/installs/MMSIM151/tools.lnx86/bin/64bit:/opt/cadence/installs/MMSIM151/tools.lnx86/bin:/usr/local/cadence/bin:/usr/local/cadence/tools/bin:/usr/local/cadence/tools.lnx86/bin/64bit:/usr/local/cadence/tools.lnx86/bin:/usr/local/cadence/share/oa/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/opt/cadence/installs/INCISIVE152/bin:/opt/cadence/installs/INCISIVE152/tools.lnx86/bin:/opt/cadence/installs/MMSIM151/tools.lnx86/dfII/bin:/opt/cadence/installs/MMSIM151/tools.lnx86/spectre:/opt/cadence/installs/INCISIVE152/bin:/opt/cadence/installs/INCISIVE152/tools.lnx86:/opt/cadence/installs/INCISIVE152/tools.lnx86/bin:/opt/cadence/installs/INCISIVE152/bin:/opt/cadence/installs/INCISIVE152/tools.lnx86/systemc:/opt/cadence/installs/INCISIVE152/tools.lnx86/bin
LD_LIBRARY_PATH:  /opt/cadence/installs/MMSIM151/tools.lnx86/cdsgcc/gcc/4.1-x86_64/install/lib:/opt/cadence/installs/MMSIM151/tools.lnx86/giganta/lib/64bit:/opt/cadence/installs/MMSIM151/tools.lnx86/mdl/lib/64bit:/opt/cadence/installs/MMSIM151/tools.lnx86/mmsim/lib/64bit:/opt/cadence/installs/MMSIM151/tools.lnx86/tcltk-8.4.20/lib/64bit:/opt/cadence/installs/MMSIM151/tools.lnx86/inca/lib/64bit:/opt/cadence/installs/MMSIM151/tools.lnx86/spectre/lib/64bit:/opt/cadence/installs/MMSIM151/tools.lnx86/dfII/lib/64bit:/opt/cadence/installs/MMSIM151/tools.lnx86/lib/64bit:/opt/cadence/installs/MMSIM151/tools.lnx86/lib:/usr/local/cadence/tools/lib:/usr/local/cadence/tools/lib/64bit/Ubuntu:/usr/local/cadence/share/oa/lib/linux_rhel50_gcc48x_64/opt:/usr/local/cadence/tools.lnx86/Qt/64bit/lib:/usr/local/cadence/tools.lnx86/dfII/lib/64bit:/usr/local/cadence/tools.lnx86/sev/lib/64bit:/usr/local/cadence/tools.lnx86/lib/64bit:/usr/local/cadence/tools.lnx86/lib:/usr/local/cadence/tools.lnx86/hdf5/lib/64bit:/opt/cadence/installs/INCISIVE152/tools.lnx86/lib/64bit:/usr/local/cadence/tools.lnx86/lib/64bit/Ubuntu
/opt/cadence/installs/MMSIM151/tools.lnx86/spectre/ahdlcmi/bin/gnumake -j20 -f GNUmakefile
Cleaning ./obj/optimize/5.0
rm -f -rf ./obj/optimize/5.0
Compiling C file resistor_v1.c (optimize)
/opt/cadence/installs/MMSIM151/tools.lnx86/cdsgcc/gcc/4.8/bin/gcc  -march=k8 -ffast-math -O3 -m64 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/opt/cadence/installs/MMSIM151/tools.lnx86/spectre/ahdlcmi/include -c resistor_v1.c -o obj/optimize/5.0/resistor_v1.o || rm -f -f obj/optimize/5.0/resistor_v1.o
In file included from /usr/include/math.h:26:0,
                 from resistor_v1.c:20:
/usr/include/features.h:367:25: fatal error: sys/cdefs.h: No such file or directory
 #  include <sys/cdefs.h>
compilation terminated.
rm -f -rf resistor_v1.c
/opt/cadence/installs/MMSIM151/tools.lnx86/cdsgcc/gcc/4.8/bin/gcc -shared -O3 -m64 -fPIC -o obj/optimize/5.0/libahdlcmi_resistor_v1.so ./obj/optimize/5.0/resistor_v1.o  -Wl,-rpath,/usr/lib -Wl,-rpath,/lib -s
gcc: error: ./obj/optimize/5.0/resistor_v1.o: No such file or directory
gnumake: *** [obj/optimize/5.0/libahdlcmi_resistor_v1.so] Error 1
gnumake: *** No rule to make target `obj/optimize/5.0/resistor_v1.o', needed by `obj/optimize/5.0/libahdlcmi_resistor_v1.so'.  Stop.
    Irene,
    I'm less familiar with Ubuntu (that appears to be what you're using from the uname output) - that explains why cat /etc/redhat-release doesn't work.
    We do support Ubuntu 14 for MMSIM15.1 (and SPECTRE16.1) - you might want to check what these two commands output:
    lsb_release -si
    lsb_release -sr
    (I'm assuming lsb_release works on Ubuntu)
    Anyway, this error (from the log file you uploaded) appears to be due to the /usr/include/sys/cdefs.h file being missing. On RedHat 6.5 this is in this rpm:
    UNIX> rpm -q -f /usr/include/sys/cdefs.h
    glibc-headers-2.12-1.149.el6_6.5.x86_64
    So I suspect you just need to install the glibc-headers package. From a little light googling, I think this is done using:
    sudo apt-get install build-essential
    on Ubuntu. If that doesn't work, you probably need to search how to install glibc header files - maybe there are other ways?
  • myungha
    myungha over 6 years ago
    Hi Irene, did you solve this issue? I have the exactly same issue and need help to solve this issue.
