  3. Ambiguity Threshold in PVS-LVS
  • Views 15597
LA2405x
LA2405x over 8 years ago
Hello all,
I am working on a project where use a number of std filler cells. In LVS, these filler cells gave parameter missmatches, with the warning of ambiguous cells in the design.
So I adjusted the Ambiguity Threshold to the suggested number, and LVS passed. Nice!
But: What is this?
I looked documentation, but all I found was how to adjust this threshold (In GUI mode: LVS Options - Comparison Options Tab - Breaking Ambiguity Threshold).
What does it affect? Is there any downside (apart from LVS speed) to have a higher ambiguity threshold?
I am glad for any information about this - Thank you very much!
Adrian
    Adrian,
    The help tells you that this GUI setting is equivalent to lvs_break_ambig_max which is covered in the PVS Developer's Guide. I suggest you search in cdnshelp for lvs_break_ambig_max as this gives more detail on how it behaves.
