  3. Virtuoso crashing on executing mgc_rve_load_setup_file command...
  • Views 14830
Virtuoso crashing on executing mgc_rve_load_setup_file command for big layouts
anandmohan
anandmohan over 8 years ago
HI
I am trying to execute  the following 'mgc_rve_load_setup_file' command in CIW for a batch of cells.( mgc_rve_load_setup_file command is used to generate calibre view from a pex netlist). For that I am using the below skill code.
procedure(pex_list()
mgc_rve_load_setup_file("calibreview_1")
mgc_rve_load_setup_file("calibreview_2")
mgc_rve_load_setup_file("calibreview_3")
mgc_rve_load_setup_file("calibreview_4")
I will load the skill file and then the function pex_netlist() is called in CIW window. For smaller cells like flip-flop,inverter etc the calibre view is getting generated.  But if I try to generate the calibre view of a larger cell (example cells with more that 10 flip-flops) the virtuoso is getting crashed. What is causing this crash. Please guide me, is anything wrong with the way skill file is being executed.
Regards
Anand
  • Marc Heise
    Marc Heise over 8 years ago
    Hi Anand,
    that function probably belongs to Mentor, you have a much better chance getting this resolved by asking them.
    Marc
