  3. When does opening an ADE-XL view cause also ViVa to open...
  • Views 15346
When does opening an ADE-XL view cause also ViVa to open?
PatrikOsgnach
PatrikOsgnach over 8 years ago
Hello all,
this is just a curiosity, but it has been tormenting for a while.
Sometimes, when a colleague of mine opens an ADE-XL view, ViVa also opens, showing the last waves that were plotted.
Sometimes, this does not happen.
On my workstation, this happens much rarely and I have been not able to reproduce this or find a root cause.
My colleagues would like ViVa to _never_ open when they open an ADE-XL view.
Which settings control this behaviour?
Thank you and best regards,
Patrik
    Patrik,
    I think this is caused by importing an ADE L state into ADE XL which has the "waveform setup" included. I thought I'd filed a CCR to get this ignored previously, but I still see it happen now and again.
    If you uncheck the "Waveform Setup" checkbox when importing an ADE L state into ADE XL, then I think it goes away.
    Either way, it's probably worth contacting customer support about because I agree this would be annoying...
    I just did a search and found that I'd filed CCR 871668 to ask for this "Waveform Setup" to be ignored (for performance reasons) but it's still not been resolved.
  • PatrikOsgnach
    PatrikOsgnach over 8 years ago in reply to Andrew Beckett
    Hello Andrew,
    thanks for the answer, but in this case there was no "import" involved, at least not a deliberate one
    Our designers always create tests via ADE-XL, they never use directly ADE-L nor they save states
    Best regards,
    Patrik
    Andrew Beckett over 8 years ago in reply to PatrikOsgnach
    Hi Patrick,
    In that case, I suggest you contact customer support via  your normal channel to see if we can get to the bottom of it.
  • PatrikOsgnach
    Cadence Support provided me with a piece of skill code that solves the problem. Unfortunately I am not allowed to share
