  3. Variable instance number and bus width depending on CDF...
  • Views 16792
Variable instance number and bus width depending on CDF parameter
Johanny Saenz
Johanny Saenz over 8 years ago
Hi all.
I want to create a variable number of instances and bus width dependent on a CDF parameter. In the same way that multibit instance from analogLib does!
How could I get it?
Thanks!
    Andrew Beckett over 8 years ago +1
    You'd have to implement a schematic and symbol pcell. For an example, see my article Creating a component that allows setting a value on a bus in an analog simulation Regards, Andrew
