  3. Measurement of delay between change in value of two buses...
  • Views 16006
Measurement of delay between change in value of two buses created using Analog to Digital function
prashantpd
prashantpd over 8 years ago
Please refer to the waveform shown in the attached screenshot.
bf_idx0_d1_o<31:0> is a bus where all the bits transition from high to low or low to high at roughly the same instant of time. However there is a slight spread in the exact time when each of the individual nets transition. This results in the 'digital' value of the bus obtained after Analog to Digital Conversion to toggle for some time before settling to a final value.
In my calculations I need to measure the time from the instant the bus reaches a stable value to the instant when a single bit output signal (op_ko) toggles in the same high-to-low or low-to-high direction.
If I use the delay function in the Visualization and Analysis XL calculator, it gives me the time from when any of the bits of the bus first cross the threshold value. The formula I am using is
awvCreateBus("bfidx0" list(awvAnalog2Digital(v("/bf_idx0_d1_o<0>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<1>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<2>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<3>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<4>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<5>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<6>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<7>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<8>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<9>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<10>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<11>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<12>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<13>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<14>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<15>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<16>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<17>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<18>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<19>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<20>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<21>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<22>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<23>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<24>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<25>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<26>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<27>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<28>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<29>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<30>" ?result "tran") nil nil 0.5 nil "centre") awvAnalog2Digital(v("/bf_idx0_d1_o<31>" ?result "tran") nil nil 0.5 nil "centre") ) "Binary")
and the value I get is 238 ps at 4.235 ns. You will however see in the figure that the bus actually stabilises at 4.3 ns.
How do I modify the formula to get this functionality.
If the screenshot is not visible in the post, I have also uploaded it to my public Dropbox here
https://www.dropbox.com/s/3njgofoda3cfajt/delay_measurement_virtuoso.JPG?dl=0
Prashant
    Prashant,
    Apologies about your post going into moderation - it was the repeated use of awvAnalog2Digital which made the system automatically think it was spam (repeated words do that).
    Anyway, it's not entirely clear what you want to measure, but I suspect you may want to convert the bus back into an analog signal (just a single analog signal for the entire bus representing the bus value as a voltage) and maybe measure its settling time to find when it stabilises (you may need to clip it to just look at the final value you're expecting). Then subtract that from the point where the other signal (op_ko) crosses the threshold.
    Something like that...
