  3. How to simulate pnoise of fractional (non-integer) frequency...
  • Views 16380
How to simulate pnoise of fractional (non-integer) frequency divider
yino
yino over 8 years ago
Hi there,
I tried to simulate pnoise of the frequency divider with a divider ratio of 4.5 (non integer value). however, I have a hard time in setting the beat frequency to be Freq_in/4.5 with relative harmonic = 1, as it complaints about the fundamental tone (=Freq_in) must be integer multiple of beat frequency. The cadence version that I use is ICADV12.3 and MMSIM version is 16.1.0.479.isr9.
Thank you in advance for all your replies.
Yin
    Yin,
    If using PSS, all frequencies must be an integer multiple of the fundamental because otherwise the result would not be periodic - you wouldn't be able to do the Fourier analysis of the interval if it contained 4.5 cycles of the fundamental.
    Presumably you could set the fundamental to be Freq_in/9 and then use relative harmonic=2 for the pnoise?
  • yino
    yino over 8 years ago in reply to Andrew Beckett
    Thanks Andrew. your suggestion works perfectly.
