  3. Measurement of ground bounce and impedance of RLC netwo...
  • Views 15119
Measurement of ground bounce and impedance of RLC network
sazjad
sazjad over 8 years ago
Hi all,
I am trying to measure the effect of power gating on the substrate noise. In other words, I want to measure the amount of ground bounce through SPICE simulation. Initially, I am planning to use lumped RLC model (attached picture) to mimic the ground network.
Now I have two questions:
1) Is that the correct approach to measure the ground bounce? If not what are the methods/metrics I should use?
2) I also want to measure the impedance of the power distribution network using this lumped RLC model for different switching activity of load circuits. I am not quite sure how to achieve this. For example: how can I get impedance vs frequency characteristics using the lumped RLC model I am using?
Please let me know if you have any question.
Thank you for your time and help.
  • sazjad
    Mr. Andrew Beckett can you please take a look into my question?
    Thank you for your time.
