  3. how to define a hot key to remove all probes in a schem...
  • Views 22996
how to define a hot key to remove all probes in a schematic
enzhu
enzhu over 8 years ago
All of you might use probes in schematic viewing. Along the way, you add more and more probes (by doing 9 and select nets). At some point you might want to remove all probes and start over by I would like to know a way to make a hot key to remove all the probes (highlights) in a schematic by Create-> Probe--> Remove All. It is pretty painful to go through this again and again.
Could anyone provide a short cut key to do this?
Thanks.
ELiang
    Andrew Beckett over 8 years ago +2
    The function you need is geDeleteAllProbe() - so you can either add this via the Options->Bindkeys UI in the CIW, or add something like this in your .cdsinit : hiSetBindKey("Schematics" "<Key>(" "geDeleteAllProbe…
  • enzhu
    enzhu over 8 years ago in reply to Andrew Beckett +1
    Hi Andrew, Great! that is exactly what I was looking for! thx. ELiang
    hiSetBindKey("Schematics" "<Key>(" "geDeleteAllProbe()")
    I picked open parenthesis because it's shift-9 on my keyboard, which is the bindkey (by default) for adding a probe so it seemed a natural place to put it.
    • Vote Up +2 Vote Down
  • enzhu
    ELiang
