  3. load different display by a hot key
  • Views 16685
enzhu
enzhu over 8 years ago
Hi All,
There is a default display file from foundry and don't want to modify directly. But would like to use a different display file to load some personal settings. Can we define a short cut key to switch between two display files?
Thanks.
ELiang
    Use drLoadDrf("/path/to/display.drf" nil)
    The nil as second argument means it won't ask you to save it when you quit virtuoso (can be a bit annoying otherwise).
  • enzhu
    enzhu over 8 years ago in reply to Andrew Beckett
    Just got a chance to try it. I am trying to make a dis.il file (and load it in CIW or init file later). But I got syntax errors by putting the following lines into the dis.il file:
    hiSetBindKey( "Schematics" "<Key>k" "drLoadDrf("/home/andy/display.drf" nil)") ;hiSetBindKey
    hiSetBindKey( "Schematics" "Shift<Key>k" "drLoadDrf("/home/andy/display_thick.drf" nil)") ;hiSetBindKey
    What I am trying to make is to use k to use thin line; K for thick line during schematic highlights.
    Could you please help to take a look at this?
    Thanks .
    ELiang
    Andrew Beckett over 8 years ago in reply to enzhu
    You need to escape the embedded quotation marks:
    hiSetBindKey( "Schematics" "<Key>k" "drLoadDrf(\"/home/andy/display.drf\" nil)") ;hiSetBindKey
    hiSetBindKey( "Schematics" "Shift<Key>k" "drLoadDrf(\"/home/andy/display_thick.drf\" nil)") ;hiSetBindKey
    Otherwise it will see the bind key string as ending after the 'drLoadDrf(' bit and then the rest would cause a syntax error because there's no space. Escaping the quotation marks needed as part of the call to drLoadDrf means that the entire command is defined as the bind key.
  • enzhu
    made it working. thx !
