  3. [HELP] How to automatically place pins over a sub block...
  • Views 6740
[HELP] How to automatically place pins over a sub block on IC6.1.6 without using skill script?
FormerMember
FormerMember over 8 years ago
Hi Cadence Forum
I am working on a chip layout and I want to place the pins of the current hierarchy layout so that it will be over the pins of a sub block.
Please see image below for clarity.
Thank you in advance.
Best regards,
    Andrew Beckett over 8 years ago +1
    Assuming you're using Virtuoso Layout Suite XL, this can be done with Place->Pin Placement. Select the pins you want to move over the top of the underlying instance, and then on the Edge cyclic in the…
    Assuming you're using Virtuoso Layout Suite XL, this can be done with Place->Pin Placement. Select the pins you want to move over the top of the underlying instance, and then on the Edge cyclic in the Attributes section below, pick "Level-1 pin". It will then move the pins to be over the pin on one of the instances to which the pin is connected.
    See the form below:
    You can also change the layer of the pin there too.
