  3. How to set "case_sensitive=yes" with ocnDspfFile
  • Views 1244
jsundermeyer
jsundermeyer over 8 years ago
ADE offers the inclusion of DSPF-files with the option that the internal nodes are interpreted case-sensitively.
When doing the same with ocean via ocnDspfFile(...) , no option is offered to activated the same behavior.. How is it supposed to be set up ?
    It's part of the string that is passed to ocnDspfFile:
    ocnDspfFile(
    "\"/export/home/myuser/support/playGPDK45/twoinv.dspf\" case_sensitive=true "
    Note that the actual file has to have quotes around it which are escaped, and then you add the case_sensitive=true flag as part of the string.
  • jsundermeyer
    jsundermeyer over 8 years ago in reply to Andrew Beckett
    That has worked fine.
     Jan
