  3. Assura DRC doesn't zoom to errors
  • Views 1532
spaceradlab
spaceradlab over 8 years ago
We are using Assura 4.15.  When running DRC, the errors are listed in the ELW.  When we try to locate the errors in the layout, error markers are visible (barely) because it does not "Zoom to Error".  It doesn't matter what Zoom Ratio we enter in the ELW Preferences.  Is there some other setting that is preventing the zooming ?
We can "Zoom to Error" only  if we view the Error Report and select the 'Shape'.  Is this a necessary step ?  Is there a way to make the errors more visible directly from the ELW ?
thanks,
jill (cadence noob)
    Jill,
    Did you press the left or right arrows as highlighted below? It's when you press these that it zooms to the error (because there could be multiple errors of each rule):
