  3. Queue list in job policies of ADE
  • Views 17980
anoopvk
anoopvk over 8 years ago
Hello All,
Under the job setup in ADE, there is a drop down under "queues" where I can select the available LSF queues. Earlier I was able to see "normal , regress, hwsim" . Now only normal is showing up there.
I got a workaround using the "asimenv.distributed" "queueNameInclusionList" variable and setting it.
I have checked "queueNameExclusionList" also. It was empty.
Since many users are facing similar issue here, I want to find the root cause for this.
Any one knows, from were these queue names are picking up? I have checked .cdsinit,.cdsenv for any environment variables, but couldn't find any.
    Very hard to be certain given that you didn't give any information about what version you're using. You may need to kill off any running cdsfrb_lsf process (note that you should wait until no jobs are running really).
    Otherwise, I suggest you contact customer support so that we can gather a bit more data rather than me making wild stab-in-the-dark guesses.
  • anoopvk
    anoopvk over 8 years ago in reply to Andrew Beckett
    Thanks for the reply Andrew.
    I am using Virtuoso 6.1.7. What my doubt is , from were these specific queue names are picking up. That is , whether it is specified in any cadence related files or picking up by any other script .
    Andrew Beckett over 8 years ago in reply to anoopvk
    There's an API that is used to retrieve the queue names from LSF - this can be checked in SKILL (it's private so I won't give it out here) - but I'm fairly sure that would match what you're seeing in the UI. It may be because the cdsfrb_lsf has got messed up somehow.
    That's why I suggested contact customer support.
