  3. Number of accepted tran steps in spectre log
  • Views 15702
anoopvk
anoopvk over 8 years ago
When a transient analysis in spectre is done, in the log file there is a statement " Number of accepted tran steps" . And it shows a big number. However in the statements above, a very few number of tran points are shown. What is the significance of these points.?
In diagnostic mode, when +transteps is used, all these points are showing in the log file
    This is controlled by the transient "annotate" option. It's set in ADE to be "status" which gives you a regular update on the progress of simulation and uses some heuristics to let you know when it's suddenly taking much smaller time steps.
    If you set annotate=steps, it will output a line for each of the 792 steps. Generally that's of little benefit though - you really don't need to see that info in the log file in general. 792 steps is not that many for any circuit that actually does something.
