  3. [IC6.1.7] Simulating VHDL-AMS
  • Views 16447
LukiLeu
LukiLeu over 8 years ago
I am trying to perform a simple simulation with a VHDL-AMS modeled resistor. Unfortunately I cannot simulate it.
I made the following:
  1. Created a new Cell View in the Library Manager with the type VHDLAMSText
  2. Added the VHDL-AMS Code to the file and saved it via File->Extract
  3. Created a symbol for the resistor (resp. Virtuoso created that automatically)
  4. Created a new Cell View in the Library Manager with the type schematic
  5. Added a simple test circuit in the schematic (One source and my resistor)
  6. Switched to the simulator and added "ideal" to the Switch View List in the Environment options
  7. Tried to create the netlist Simulation->Netlist->Create
Unfortunately the following error occurs:
Netlist Error: Cannot find any info on instance "I1" in cell-view "fh_hall_elements" "test" "schematic"
Netlist Error: Some cell-views used inside this block could not be netlisted in analog context
The element I1 is my resistor.
Any ideas on how to resolve this error?
Code of the resistor:
library ieee, std;
use ieee.std_logic_1164.all;
use ieee.electrical_systems.all;
use ieee.mechanical_systems.all;
use std.textio.all;
use ieee.math_real.all;
entity myres is
port (terminal p1, p2: electrical);
end entity myres;
architecture ideal of myres is
constant R : real := 10.0e3;
quantity v across i through p1 to p2;
begin
i == v/R;
end architecture ideal;
    First of all, you didn't mention which simulator you're using - but from what you've said, it can't be "ams" (which is what you need if using a Cadence simulator and want to simulate VHDL-AMS models). It can't be ams because if using ams you'd have to have a config, and then Setup->Environment doesn't show the switch view list any more.
    I'm assuming you're trying to simulate with spectre as the simulator, and this does not support Verilog-AMS or VHDL-AMS - primarily because the "MS" bit means "mixed-signal" and hence you'd need some digital engine in the simulator.  So you need to use "ams" (AMS Designer) as the simulator; if you do that, you'd need to create a config view and set the view to use (or switch view list) there (AMS requires you to use a config created in the hierarchy editor).
  • LukiLeu
    LukiLeu over 8 years ago in reply to Andrew Beckett
    Thank you for your response. I was indeed using Spectre as simulator. With the ams Simulator and the config view it works now.
    Thank you for this hint.
