  3. ADE-XL: Save statistical scatter plot setup
  • Views 16398
drdanmc
drdanmc over 8 years ago
I've been making use of creating scatter plots of pairs of outputs in a Monte Carlo sim.  This has been very useful.  What is not so convenient is I haven't found a way to save my scatter plot setup to where I can automatically get my desired scatter plots after a simulation finishes.  I have to bring up the scatter plot form and pick my X and Y results each time.  Is there some way that I'm missing for storing this setup?
IC617 (6.1.7-64b.500.14), ADE-XL.
-Dan
  • mschw
    mschw over 8 years ago
    Dear Dan,
    probably you can try that:
    1. Within ViVA you could select all scatter plots you'd like to be saved
    2.If you press the right mouse button and select "Send To" --> "ADE"  these scatter plots will be added to ADE-XL outputs
    Kind regards,
    Matthias
  • drdanmc
    drdanmc over 8 years ago in reply to mschw
    That almost works but it seems to cause some errors though because the result can't be updated for each iteration which is what ADE-XL tries to do.  Good idea though.
    Andrew Beckett over 8 years ago in reply to drdanmc
    Dan,
    You might need to set the evaltype to "all" (only available in ADE Assembler) to get this to work - that way it's done at the end. Note, I've not tried this at all.
    Either way, it's a reasonable thing to want to do - if it's not working, you should contact customer support.
