  3. calibre results directory
  • Views 15046
nicola91it
nicola91it over 8 years ago
Hi to everybody,
I have the need to change the directory where the calibre results are saved. For the simulations, I use the following in my cdsinit file:
envSetVal("asimenv.startup" "projectDir" 'string "MY_SIMULATION_DIRECTORY")
Should I do the same for calibre? For example the following line?
envSetVal("asimenv.startup" "projectDir" 'string "MY_CALIBRE_DIRECTORY")
Thank you in advance
Nicola
    Nicola,
    Calibre is not an analog simulator - that setting is to control where simulation results in the Analog Design Environment are saved. For Calibre presumably there is some other control, but since it is a Siemens Mentor product (not a Cadence product), these forums are probably the wrong place to ask...
  • nicola91it
    nicola91it over 8 years ago in reply to Andrew Beckett
    Ah ok, sorry for that then and thank you for the fast reply. Regards,
    Nicola
