  3. How to import verilog code into virtuoso?
  • Views 27638
raveensrk
raveensrk over 8 years ago
I have a sequence detector verilog code. I want to import it into cadence virtuoso and simulate it along with my other circuits.
I am using the Virtuoso custom ic design environment version IC6.1.6-64b.500.14.
I have checked some online guides and manuals to do this but somehow I always end up with errors. Is there an correct method to do this? Because the online manuals are for different version of virtuoso.
    The documentation is (and has been for probably the last 25 years) provided with the software installation - and that should be consistent. If you run <ICinstDir>/tools/bin/cdnshelp - or in the CIW just do Help->User Guide. Then in the User Guide use View->Show Navigation - and you can search in there. Or use File->Import->Verilog and hit the Help button on the form - that takes you to the right place.
  • raveensrk
    raveensrk over 8 years ago in reply to Andrew Beckett
    Thank you. I was able to get the correct documentation.
