  3. A file needs to know it's place in the world
  • Views 909
CADcasualty
CADcasualty over 8 years ago
I have a file that contains skill code that can modify it's behavior based in where it exists within the file system. Is there a way for the file to determine the name of its unix parent folder?
    Yes. See this forum thread - essentially using get_filename(piport) in your script. Well, that's returning the filename being read - from which you could of course determine the containing directory. That thread also talks about being able to do it inside a function defined within a SKILL file (rather than defining a global variable to determine where the file is) - which wasn't documented at the time. It is now documented in the SKILL Language User Guide, in a section headed "Read-time Evaluation" which says:
    SKILL provides the read-time eval operator #. for evaluating expressions at read-time.
    When this operator is encountered, the expression following the dot is evaluated and the
    result of this evaluation replaces the #. For example, in the code below
    get_filename(piport) is evaluated at read-time and the results are inserted when the
    entire expression is compiled:
    procedure(printFileThisWasFrom()
      printf( "The file is:%s\n" #.get_filename(piport) )
    If this function was defined within a file "code.il" then after the read-time evaluation, the
    expression would expand to the following, before being passed to the SKILL evaluator:
      printf( "The file is:%s\n" "code.il" )
  • CADcasualty
    CADcasualty over 8 years ago in reply to Andrew Beckett
    As always - thanks for your swift and perfect response!
