  3. Menu Assura only in windows Layout not present in the window...
  • Subscribers 133
  • Views 6210
Menu Assura only in windows Layout not present in the window Schematic
AndreyVolk
AndreyVolk over 8 years ago
Hi, All.
I noted that menu Assura only in windows Layout and not present in the windows Schematic.
I think menu Assura should also be in the Schematic window? Or I am mistaken?
    No, it's only in the layout window. There was some talk of adding some support in the schematic menus back in IC615, but looks as if we decided against it. Not sure why...
  • AndreyVolk
    AndreyVolk over 8 years ago in reply to Andrew Beckett
    Ok, thank you Andrew.
    I remembered that I had seen the Assura menu in the window Schematic before.
    And I thought something wrong set up.
