  3. Virtuoso XL LE: Extract connectivity through "empty" ar...
  • Views 1646
Virtuoso XL LE: Extract connectivity through "empty" areas
RVERP
RVERP over 8 years ago
In layout XL, there are layers defined that are electrically connected. However, in most technology, the substrate is just empty area.
So is there a way to set up the techno so this empty areas are electrically connected? For example, everything that is not NWELL, is PSUB, and must connect to P+ diffusion.
    There's a section on this in the documentation. Search for "Connectivity Extraction from Substrate and Well Layers" in cdnshelp (include the quotation marks in the search) and you'll find the section.
    There's also an option on the Options->Layout XL (Connectivity Tab) called "Enable substrate verification and set well layers as soft" that I think you'll need to turn on (I didn't test this myself to be sure - just wanted to give you some pointers in the right direction).
