  3. Monte Carlo Design Variables?
  • Subscribers 138
  • Views 20969
drdanmc
drdanmc over 8 years ago
I would like to run a monte carlo simulation in ADE-XL (well, actually I want to run in Ocean-L but that is no longer supported) where some of my design variables have variation.
I tried as an example, instantiating an analogLib/vdc voltage source with dc=MYVDD.  Then I put in MYVDD=1 in the design variables list.
Then I created a spectre model file that included:
parameters my_vdd_mc=1
statistics {
  process {
    vary my_vdd_mc dist=unif N=0.2
my_alter_vdd alter param=MYVDD value=my_vdd_mc
and included this in my model setup.  I picked all (process+mismatch) for the simulation but the simulated (monte carlo) voltage is rock solid at 1.0V, no variation at all.  Looking at input.scs and spectre.out it is clear what the issue is.  The alter commands are *outside* of the monte carlo loop instead of inside it which isn't all that surprising.  Ok, so how to fix that?
I tried directly using dc=my_vdd_mc in the test bench schematic (i.e. skip the alter statements).  Now ADE-XL freaks out because it says "hey, you are trying to use my_vdd_mc but I don't know anything about it".  Yes, I know ADE-XL doesn't know anything about it, the model file I created adds it.
So... I guess my next approach will be to create a cell "my_supplies" that has a symbol and spectre view and then put the voltage source in the model file as well.  However, this seems like a pain and gives less flexibility, especially if I needed to use the statistically varying variable in multiple spots.
Is there anyway to tell ADE-XL to cut me some slack on defining a parameter in a model file instead of via the GUI?
-Dan
  • mschw
    mschw over 8 years ago
    Dear Dan,
    have you tried just adding
    statistics {
      process {
        vary MYVDD dist=unif N=0.2
    to the new spectre model and include it and run the mc-simulation? I think the way to directly add dc=my_vdd_mc in the schematic and skip the alter&paramater statements will work if you'll add my_vdd_mc as a design variable.
    Kind regards,
    Matthias
    Andrew Beckett over 8 years ago in reply to mschw
    Was going to either suggest what Matthias suggested - defining the mean value in the global variables and just the statistics in the included model file, or alternatively if you keep the variable my_vdd_mc just set the global variable MYVDD=my_vdd_mc in the ADE global variables (rather than using an alter, which won't work, as it's an analysis outside of the monte carlo, and isn't really needed when just an assignment would do).
  • drdanmc
    drdanmc over 8 years ago in reply to Andrew Beckett
    Cool, using the variable in the globals section was the ticket.  I'm keeping the variable instead of using the global to set the mean because we use a common model file (typically with the alters for non-montecarlo) and a standard set of design variables to keep the whole team on the same page for supply and temperature limits.  It avoids the "really, we have to operate at __ degrees/volts?  I thought it was __ degrees/volts." discussion during a design review.
    -Dan
