  3. VHDL AMS and LTF
  • Views 15909
VHDL AMS and LTF
LukiLeu
LukiLeu over 8 years ago
I'm trying to simulate a simple opamp model which is written in VHDL AMS. Unfortunatly the AMS Simulator does not simulate it and produces the following error:
Analog Kernel using -ANALOGCONTROL  ./amsControlSpectre.scs.
Reading file:
        /.../netlist/amsControlSpectre.scs
ncsim: *E,EUNLTF: /.../vhdl.vhms:101: vin'LTF_101_15: The parameters of the LTF attribute must be aggregates of scalars.
Error found by spectre during circuit read-in.
    ERROR (SPECTRE-357): AMS Analog Elaboration has exited with error.
        Simulation will terminate.
The corresponding part of the model looks as follows (wP1, wP2 and gain are real generics):
constant num : real_vector := (0 => wP1 * wP2 * gain);
constant den : real_vector := (wP1 * wP2, wP1 + wP2, 1.0);
vout == vin'ltf(num, den);
Are their any ideas in how to resolve this error?
  • mschw
    mschw over 8 years ago +1
    Have you tried vout == vin'ltf((0 => wP1 * wP2 * gain), (wP1 * wP2, wP1 + wP2, 1.0)); ? Kind regards, Matthias
  • mschw
    mschw over 8 years ago in reply to LukiLeu +1
    Dear Lukas, you can find the Cadence VHDL-AMS Overview in the Cadence Installation directory /doc/vhdlamsov/vhdlamsov.pdf or here . I suppose since the LTF syntax requires aggregates of scalars a array…
  • mschw
    Have you tried
    Kind regards,
    Matthias
  • mschw
    mschw over 8 years ago in reply to mschw
    I think that my upper suggestion will not work either. You might  take a look in the Cadence VHDL-AMS Overview . There, the use of LTF Systax is explained exactly (Section Examples of Attribute Use: Q'ltf)
    Kind regards,
    Matthias
  • LukiLeu
    LukiLeu over 8 years ago in reply to mschw
    Hi mschw
    Your suggestion without the constants is working. The question is just why? However I can live with that solution. Where can I find the Cadence VHDL-AMS Overview, I wasn't able to find it...
    Thank you
    Lukas
  • mschw
    Dear Lukas,
    I suppose since the LTF syntax requires aggregates of scalars a array reference cannot be used.
    Kind regards,
    Matthias
