  3. Library Manager display settings
  • Views 16597
Aldo2
Aldo2 over 8 years ago
I defined in Library Manager -> Edit -> Display Settings, some custom settings.
How could I change them? Is there an editable configuration file in which they are saved?
Thank you
Best regards,
Aldo
    Aldo,
    They're saved in .cadence/libManager/displayPrefs (which is an XML file). Because it's in .cadence the libManager/displayPrefs will be searched for in .cadence directories that are in the "setup.loc" locations (i.e. using the "Cadence Search File" mechanism). So it will use the merge of all the displayPrefs files found using (the UNIX command):
    cdswhich -all .cadence/libManager/displayPrefs
  • Aldo2
    Aldo2 over 8 years ago in reply to Andrew Beckett
    Thank you very much
    BR,
    Aldo
