  3. not_gate verilogA model in ahdlLib
  • Views 18350
VLSIiitm
VLSIiitm over 8 years ago
The following lines are in the verilogA model of "not_gate" in ahdlLib. I have marked 3 lines as A, B, C.
@ ( initial_step ) begin
... <<deleted lines>>
end
logic_in = V(vin) > vtrans; // line A
@ (cross(V(vin) - vtrans, 1))  logic_in = 1; // line B
@ (cross(V(vin) - vtrans, -1)) logic_in = 0; // line C
  • What is the reason for having both line A and lines (B,C)? Latter seem to imply the former unless the inputs don't cross the threshold at all during the transient simulation.
  • Would it have been enough to have line A within @(initial_step) begin  ... end?
  • If line A is indeed redundant, does having it slow things down because it is continuously evaluated?
Other gates have similar codes.
Nagendra
    Nagendra,
    One benefit is that this wouldn't have hidden states for SpectreRF because logic_in is updated on every timestep. Without line A, it would only get recorded on the crossings - so there would be no initial value, and SpectreRF would not be able to simulate it. The @cross is needed to ensure that there is a timestep at the transition.
    I probably would have written it just as:
    @(cross(V(vin)-vtrans)); // force timetep at transition (either direction)
    logic_in=V(vin)>vtrans;
    I don't think it will make any significant difference to the performance.
  • VLSIiitm
    VLSIiitm over 8 years ago in reply to Andrew Beckett
    Thanks. Out of curiosity, will pss with initial transient(tstab) look at what is inside @(initial_step) begin ... end?
    Andrew Beckett over 8 years ago in reply to VLSIiitm
    Yes, it should do. Note, I didn't actually test this model with pss - this is from visual inspection only...
