  3. Parametric Analysis - Random Values
  • Views 1453
vijaykpd
vijaykpd over 8 years ago
Hi Friends,
In the ADE L - parametric analysis, I could see options to sweep the variable in the linear/logarithmic/auto etc between the specified min and max values. But is there any option to provide random values to the variable. So I would like to vary the parameter randomly within the min and max values and see the performance of the circuit. Kindly provide your suggestion.
Thanks in advance
Vijay
    Andrew Beckett over 8 years ago +1
    No. Could you use monte carlo instead? Andrew
  • vijaykpd
    vijaykpd over 8 years ago in reply to Andrew Beckett
    Thank you very much Andrew for your quick reply. I will try Monte Carlo analysis
    Vijay
