  3. How to set conditional tests in ADEXL to avoid running tests...
  • Views 16282
How to set conditional tests in ADEXL to avoid running tests not needed in a sequence of tests.
angcol
angcol over 8 years ago
Hello All,
I am currently executing a pre-trim and pos-trim checks for an oscillator using ADEXL and Montecarlo sampling with the PSS tool. In the initial pre-trim I ran the simulation bench at 27degC and find a gross code approximation. Then in several post-trim simulations I refined the search to obtain the best code. I used a combination of "calcVal" and "VAR" to share information between the consecutive tests. The problem is that I am spending like 5 tests to find the best code even if in my first test I already found the best code. I would like to find a way to not enable the next tests if I already found the code in the first tests. Something like a conditional that if the error is less than half the LSB I would not run the next post-trim tests and I would run just the last two tests, that are actually at a different temperature sharing just the best code found in the first tests.
The sequence I follow is:
1) Run test at 27 degC and find the approximated code to center the frequency of the oscillator.
2) Run same test at 27degC with the code found in 1). Measure frequency and find a better code than in 1).
3) Run same test at 27degC with the code found in 2). Measure frequency and find a better code than in 2).
4) Run same test at 27degC with the code found in 3). Measure frequency and find a better code than in 3).
5) Run same test at 27degC with the code found in 4). Measure frequency and find a better code than in 4).
6) Run same test at 27degC with the code found in 5).
7) Run same test at -40degC with the code found in 5).
8) Run same test at 125degC with the code found in 5).
If the error during any of the steps 2) to 5) is less than the desired accuracy do not execute more tests at 27degC and jump directly to tests 7) and 8) saving the best code found in that specific test.
I already have this sequence working from 1) to 8) but I would like to save tests if they are not needed.
Thanks a lot for any help you can give me.
angel
    Hi Angel,
    This can be done in ADE Assembler (the new product which is the next generation from ADE XL) in IC617. In essence you can create what are called "Run Plans" - and these can have conditions as to whether they run or not. You may need a little bit of a script associated with the run plan to get the right code (i.e. from the right run plan test) but I can see how it would be done.
    If you've got access to ADE Assembler, contact customer support to talk this through in more details. If you haven't got access to ADE Assembler, you probably should talk to your account team.
    Kind Regards,
  • angcol
    angcol over 8 years ago in reply to Andrew Beckett
    Thanks a lot Andrew for your prompt answer. I will contact my Account team. I was thinking also if there is a trick to speed up the PSS simulation cheating the tool to run quickly (I tried this but without success) or if I can instantiate some verilogA block that based on error being low in the previous test, it can terminate the test quickly and just share the best code found in the previous test to just the last two tests.
    Andrew Beckett over 8 years ago in reply to angcol
    That might be possible, but I suspect it's quite difficult to implement (if at all). Could also potentially implement this using a loop in a pre-run script (right mouse button over the test in ADE XL) which keeps looping until a good result is achieved (or it gives up). Again, customer support can give you some help with that - that might be simpler still.
  • angcol
    Thanks again Andrew for the reply and the suggestion. Have a great day.
