  3. more pin name and net name checking at check and save
  • Views 15655
enzhu
enzhu over 8 years ago
How to add in more custom checking during the check and save? For example, we would like to forbid some specific keywords (say, verilog keywords in a list file) for pin names or even wire/net names. By doing that, we can avoid analog designers using some digital keywords which might cause some potential unnecessary issues.
The whole idea might be like this: at the check and save, a skill would be triggered to load the list and check against it.
Thanks.
  • Quek
    Quek over 8 years ago
    Hi Enzhu
    You can use schRegPostCheckTrigger function to automatically execute a SKILL procedure after check&save. Please see $CDSHOME/doc/skcompref/skcompref.pdf.
    Best regards
    Quek
    Andrew Beckett over 8 years ago in reply to Quek
    In addition to the function that Quek mentioned, there's also some newer infrastructure (which has existed since IC615 - so for the last 7 years) to define custom checks which update markers and can be controlled via the check setup form. I give an example in this forum post.
  • enzhu
    enzhu over 8 years ago in reply to Andrew Beckett
    Thanks to Andrew and Quek!
