  3. Verilog-A model and temperature in AC-Sim
  • Views 21521
HoWei
HoWei over 8 years ago
I have a verilog-a model that is dependent on the simulation temperature, using the "$temperature" variable.
The temperature value changes vs. corner simulations. The simple model gives a voltage in dependence on the temperature.
The following code works:
analog begin
   V(out,vss) <+ $temperature-273.15*V(in,vss); //Input voltage is always 1V
end
This code does always give me 27 degC:
real temp_degC = 27;
analog begin
   temp_degC = $temperature-273.15;
   V(out,vss) <+ temp_degC*V(in,vss); //Input voltage is always 1V
end
Why is that and how can I make the model evaluating the "temp_degC" correctly ?
  • HoWei
    I figured, when I do not initialize the variable, it is evaluatting the variable value at runtime as expected and ist working:
    real temp_degC; //not initialized
    analog begin
    end
    Why is that ?
    Is an initialized variable treated like a constant ?
    Andrew Beckett over 8 years ago in reply to HoWei
    This appears to be a bug. I've tried in various versions, and if the variable is initialized and then assigned to an expression including $temperature, it doesn't work. If instead the assignment within the analog block is:
    temp_degC=55.0;
    then it works (so it's not a constant). Also, if you do:
    @(initial_step) temp_degC=$temperature-273.15;
    then it also works. I filed CCR 1887528 for this - it would be a good idea if you report this to customer support yourself and request a duplicate CCR is filed (that way it is clear it's coming from a real customer) - however, I'm hopeful that we'll get this inconsistency fixed anyway.
  • HoWei
    HoWei over 8 years ago in reply to Andrew Beckett
    Thanks for confirmation and the Workaround via @(initial_step).
    i submitted a case  #46255884 via customer support Portal.
