  3. Veriloga parameter expression
  • Views 19420
RobinCommander
RobinCommander over 8 years ago
In veriloga documentation I have seen examples where one parameter is used to set the default of another parameter in the same module.
When I tried this I found it didn't work in ADE/spectre. A simple example:
`include "constants.vams"
`include "disciplines.vams"
module test_param(n1, n2);
inout n1, n2;
electrical n1, n2;
parameter real myres = 1k;
parameter real twores = 2*myres;
analog begin
I(n1, n2) <+ V(n1, n2)/twores;
end
endmodule
When I tried simulating this in a test bench, ADE added myres to the list of design variables to be set.
If I try running without setting a value I get an error:
Error found by spectre during hierarchy flattening.
ERROR (SFE-1997): "input.scs" 14: I0: parameter `twores': Cannot run the simulation because parameter 'myres' has been used but no value has been assigned to it. Assign a value to the parameter and rerun the simulation.
Is this a bug?
Robin
  • vijaykpd
    vijaykpd over 8 years ago
    Dear Robin,
    Please refer the work around proposed by Andrew. I think you need to do the following steps
    Tools->CDF->Edit, pick "Base" CDF and edit the CDF of your cell (the one with the VerilogA model). Delete the myres parameter, and OK the forms
    Vijay
    Andrew Beckett over 8 years ago in reply to vijaykpd
    Vijay, Robin,
    Note, you don't need to delete the parameter (in fact it's not the myres parameter that's really the problem). When the CDF for the component is created, it creates two CDF parameters with default values:
    myres: 1000
    twores: (2)*(myres)
    The issue is that when the component gets netlisted, it adds both of these parameters on the instance line - and then myres is in spectre's scope and it looks for a global parameter called that.
    All you need to do is go to the Tools->CDF->Edit CDF in the CIW, pick "Base" and the test_param component, and then blank out the default value of twores. That will then mean that the default value is taken within the model, and the problem goes away.
  • RobinCommander
    RobinCommander over 8 years ago in reply to Andrew Beckett
    Vijay, Andrew,
    OK thanks, blanking the default for the derived parameters fixed the problem.
    I found I would need to do the CDF edit again if I changed the VerilogA, even just adding some comment lines, but not really an issue.
    Robin
