  3. *WARNING* Connection to MACHINE failed. No route to hos...
  • Views 15947
*WARNING* Connection to MACHINE failed. No route to host
mschw
mschw over 8 years ago
when I want to start PVS in the Virtoso Layout Editor I get the warning *WARNING* Connection to MACHINE failed. No route to host in the CW. (MACHINE=name of the machine on which I started Virtuoso). When I start PVS standalone (from the terminal) everything works pretty fine.
How can I get more detailed information on what causes this warning?
Kind regards,
Matthias
    Matthias,
    Not sure. Best would be to contact customer support. First thing I'd check is what /etc/hosts contains on the machine in question (perhaps you can post it here?).
  • mschw
    mschw over 8 years ago in reply to Andrew Beckett
    Andrew,
    thanks for your quick reply. I compared /etc/hosts of this machine with /etc/hosts of  another machine on which PVS works without problems: they are identical. So that shouldn't be the problem.
    I think I need to hand that over to our admin...
    Matthias
