  3. how to customize right click menu in adexl data view window...
  • Views 15838
how to customize right click menu in adexl data view window and add save option
sjwprc
sjwprc over 8 years ago
    I am using adexl to run analog design. In general, there are many functions in the right click menu in the data view window, when you right click your test name. At the same time, I find the output save option is not included in this menu, and I have to open ade L editor to edit such saving signals and save option every time.
    Is there any way to add&customize saving option to right click menu ?
BR
  • sjwprc
    sjwprc over 8 years ago in reply to Dimitra Papazoglou +1
    Done, thanks for your answer.
  • Dimitra Papazoglou
    Dimitra Papazoglou over 8 years ago
    I think you are referring to the 'Save Options' form. Instead of adding an item to right click menu what you can do is:
    After adding one at least output for the test in Outputs Setup tab then select the output -does not matter which cell you select- and do RMB->Save all… The 'Save Option' form pops up and you can set the Save Options/Save circuit information analysis/Output Options there. The settings apply on the test of selected output. Follow the same process for modifying the Save settings of the rest of the tests of the adexl view.
    You can also select the output and do RMB->To be saved… or RMB->To be Plotted… to add signals to be saved and plotted in the Outputs Setup, likewise you do in ADE-L.
    Dimitra
  • sjwprc
