  3. eyeDiagram() vs. Measurement --> Eye Diagram trigger pe...
  • Views 4531
eyeDiagram() vs. Measurement --> Eye Diagram trigger period
HoWei
HoWei over 8 years ago
in the result browser, the Measurement --> EyeDiagram lets me plot an eye diagram vs. a trigger periode generated from another signal - that's what I need.
The function "eyeDiagram()" only allows a constant trigger period - that is not what I want, because over corners the trigger period changes, and I want to get the eye diagram over corners.
How can I create an eyeDiagram() function with trigger period derived from another signal ?
    Generate the Eye Diagram with the assistant, then having plotted it, select the Eye Diagram and use Right Mouse->Send To->Calculator. You'll see that this generates an expression using edgeTriggeredEyeDiagram().
  • HoWei
    HoWei over 8 years ago in reply to Andrew Beckett
    Yes, that's what I want - works great !
    Thanks !
