  3. Full OSSHNL error list
  • Views 18113
goofycat
goofycat over 8 years ago
Occasionally we get error message:
ERROR (OSSHNL-514): Netlisting failed due to errors reported before. Netlist may be corrupt or may not be produced at all. Fix reported errors and netlist again.
                simDcmFIlePath
But searching with “OSSHNL” prefix shows nothing in help. Is there a list of all OSSHNL errors, like for example Windows Error Codes?
G
    Andrew Beckett over 8 years ago +1
    No. The main purpose of the error codes is to help us track down precisely which bit of code is generating the error; the goal is that the error message is self-explanatory (in fact the wording was changed…
    No. The main purpose of the error codes is to help us track down precisely which bit of code is generating the error; the goal is that the error message is self-explanatory (in fact the wording was changed in IC616 ISR1 to be slightly different from above, so you must be using an old version from before that).
  • goofycat
    goofycat over 8 years ago in reply to Andrew Beckett
    Thanks, I got it.
    does this forum has "mark as solved" button or something, like on MSDN forums for threads?
    Andrew Beckett over 8 years ago in reply to goofycat
    No, sorry.
  • goofycat
    I see.
