  3. CDF doneProc callback no longer runs.
  • Views 15101
MatthewLove
MatthewLove over 8 years ago
I have a symbol that sets some CDF parameters using a callback with the doneProc event.
I now get the following error "*WARNING* An error occurred while applying the CDF doneProc 'X' to (db:0x17f5a99a)"
(X is put in place of the name of the callback)
The error is quite vague so I'm not sure what to do
    Try using:
    sstatus(errsetTrace t)
    _stacktrace=50
    and then it should give more info (the second is only really necessary if the error message itself isn't enough). What is happening is that your doneProc has an error in it, but we catch the error so that it doesn't break everything.
  • MatthewLove
    MatthewLove over 8 years ago in reply to Andrew Beckett
    Thanks Andrew, that got the error to print.
    It was just a small mistake in my script, I accidentally entered a random character at some point which broke it.
