  3. how to activate Spec Markers in ADEXL Plotting Options ...
  • Views 16005
how to activate Spec Markers in ADEXL Plotting Options ?
sjwprc
sjwprc over 8 years ago
     I try to use the following command to activate Spec Markers in ADEXL Plotting Options, but failed. Anyone has clue ?
     envSetVal("asimenv.plotting" "specMarkers" 'boolean t)
BR
  • Dimitra Papazoglou
    Dimitra Papazoglou over 8 years ago
    What IC version are you using? To find out, in CIW do Help->About Virtuoso
    Dimitra
  • sjwprc
    sjwprc over 8 years ago in reply to Dimitra Papazoglou
    Hi, the version is IC6.1.7-64b.500.17.
    Dimitra Papazoglou over 8 years ago in reply to sjwprc
    What I see is that when creating a new adexl view then the env var works ok. So changing “specMarkers” to t/nil in CIW  I see the ‘Spec Markers' option is enabled/disabled accordingly.
    Now in the ‘ADE XL Plotting/Printing Options’ if I change the 'Plotting Option' from None(default) to e.g Auto or Refresh then changing “specMarkers” to t/nil stops working.
    I’d suggest you to file a ticket on customer support.
    Dimitra
  • sjwprc
    Clear answer, fixed.
    Thanks !
