  3. x_count@techDerivedLayers : formal definition?
  • Views 1090
goofycat
goofycat over 8 years ago
techDerivedLayers(
( t_derivedLayerName x_derivedLayerNum
( tx_layer1 s_op tx_layer2 )
[ x_count | t_rangeVal ]
[ 'diffNet | 'sameNet ]
[ 'exclusive ]
x_count The number of times contact must be made between the shapes on the two layers forming the derived layer. Valid Values: Any non-negative integer.
although there is good explanation on various s_op, the document lacks definitions on x_count is reckoned. If we have rect1 on layer1, covering <topleft,bottom right>{{-1,0},{0,-1}}, and rect2 on layer2, covering <topleft,bottom right>{{0,0},{1,-1}}, the two shares an infinitely thin edge. There are lots of trivial cases like this.
So how is the "number of contacts" counted? By counting pieces of mininum area block? Please provide a formal definition.
G
    Andrew Beckett over 8 years ago +1
    I don't think I've ever seen that being used anywhere (it's optional and all the tech files I quickly checked didn't use it), and I couldn't find any better description anywhere. I could hazard a guess…
    I don't think I've ever seen that being used anywhere (it's optional and all the tech files I quickly checked didn't use it), and I couldn't find any better description anywhere. I could hazard a guess, and if I had time I would do a bunch of experiments to prove that. I just found actually that the sample2007.tf file in <ICinstDir>/tools/dfII/samples/techfiles uses this.
    However, the best thing to do if you need this is to contact customer support. I agree, the documentation could be clearer.
  • goofycat
    goofycat over 8 years ago in reply to Andrew Beckett
    got it, thanks.
