  3. Monte Carlo Simulations of Extracted Layout
  • Views 15816
MohsenShah
MohsenShah over 8 years ago
I wanted to do the Monte-Carlo simulations on a extracted layout (DC analysis). As recommended by a previous comment, I made a "config" view for the test-bench and did the DC analysis in ADEL successfully. However, when I am going to do it for the extracted view in the ADEXL, I receive this error:
"Monte Carlo run stopped because no statistical data generated for the test"
Does anyone has an idea how can I solve this problem? As another question, can I use some schematic designs together with these extracted views and do the Monte Carlo simulations on them? In other words, I do not have the layout of some blocks but I like to know how to they work with the extracted blocks. My Cadence version is IC6.1.6-64b.500.6
Thanks!
  • Dimitra Papazoglou
    Dimitra Papazoglou over 8 years ago
     Does this error pop up in the beginning , middle or end of the postlayout simulation? Once you click on the "Close" button in the pop-up form, what errors you get in the Results tab? Select one of the errors and then do RMB. If "Output Log" is there can you have a look for errors there and possibly share that part of it?
    To answer your last question, you can run MC simulations having both schematic and extracted views together.
    Dimitra
  • MohsenShah
    MohsenShah over 8 years ago in reply to Dimitra Papazoglou
    Thank you for your prompt response. Error started in the beginning of the simulation. I understood that I have forgotten to include libraries in the the Model Library in the ADE XL. Now that I included them, I ran the simulation successfully. Thanks!
