  3. check spacing between nets with Diva DRC - Net tracing with...
  • Views 2019
check spacing between nets with Diva DRC - Net tracing with Diva - Need inputs
Naveen Premkumar
Naveen Premkumar over 8 years ago
I am writing a diva drc deck to check for space between two nets (not shapes) A net can have a bunch of shapes that are connected.
I tried the below way to do this,
- trace the nets Net1_name and Net2_name.
- compare drc() between them
drcExtractRules(
m1 = geomOr("M1")
via1=geomOr(via1)
... upto top metal
;connect all shapes
geomConnect(
label( ("m1" "label") m1)
via(via1 m1 m2)
label( ("m2" "label") m2)
via(via2 m2 m3)
... up to top metal
;get the shapes that belong to the required net
netm1 = geomGetNet(m1 "Net1_Name")
netm2 = geomGetNet(m2 "Net2_Name")
.... upto top metal
fullNet1 = geomOr(netm1 metm2 ...)
netm1 = geomGetNet(m1 "Net2_Name")
.... upto top metal
fullNet2 = geomOr(netm1 metm2 ...)
;compare drc between them
saveDerived(drc(fullNet1 fullNet2 0<sep<10) "DRC error")
Problem with this approach is that it takes way too long to run for a big cell even though the nets I am looking for a very small. I found that the connect statement is the one that seems to take a lot of time as it tries to connect the whole layout which is not necessary.
Any suggestions on how to do this in an efficient way.
Naveen
  • Naveen Premkumar
    drcExtractRules(
    m1 = geomOr("M1")
    via1=geomOr(via1)
    ... upto top metal
    ;connect all shapes
    geomConnect(
    via(via1 m1 m2)
    via(via2 m2 m3)
    ... up to top metal
    .... upto top metal
    .... upto top metal
    Naveen
    Andrew Beckett over 8 years ago in reply to Naveen Premkumar
    Because you had filed two posts for the same issue in two different forums (the Forum Guidelines explicitly ask you not to do this - it creates confusion and means that nobody knows where to answer the question, and potentially doubles the effort needed to respond; please read the guidelines), I merged your two posts.
    Probably the sensible thing would be to use something more modern and scalable than Diva, such as Assura (similar rules) or PVS. Diva is very old and not well-suited to large designs.
