  3. [URI] RelXpert support for HISIM_HV model cards.
  • Views 15005
FAVG
FAVG over 8 years ago
Hello All,
I am implementating an aging model using the URI for a transistor techonology using a HISIM_HV model card.
The implementation works fine when I run the simulation using the Spectre Native option,  but when I try to do it using RelXpert, the tool produces  an error stating  that model level  is not supported.
It seems that the mistake comes when RelXpert parses the Netlist, even before the simulation begins
It is there any information regarding what Model Cards types are supported by RelXpert, or if the Model cards should be define in a specific manner, so RelXpert can use it.
Like I said before, the implementation works perfectly with Spectre Native reliability Block.
Thanks in advance for your help
Best Regards,
Fabio
    Fabio,
    I suggest you raise this with customer support - it's going to to be hard to debug without more details of precisely what you're doing.
    Also, if it works with spectre native, there's not a huge reason to use RelXpert; the native mode is intended really to be a more direct way of running reliability analysis than the older RelXpert flow.
    Kind Regards,
