  3. QRC Lvs Extracted View
  • Views 17418
PietroUser
PietroUser over 8 years ago
I am using QRC with LVS Extracted View output in order to generate the circuit netlist from the layout.
The netlist (created with ADE-L) is the reported below. However I would like to add a custom extra line in a given subckt section (i.e I0 (net1 net2) myblock) to include an additional parasitic model for my MEMS simulation.
Is there a method for adding such a line in a spectre netlist (i.e. nlPrintComment netlister ....)?
Pietro
// Library name: test
// Cell name: diode_Test_Top
// View name: av_extracted
// Inherited view list: spectre cmos_sch schematic veriloga ahdl
subckt diode_Test_Top D G S Sub
avD218_3 (NW2 I1\|net11) iprobe
avD218_2 (NW1 I1\|net11) iprobe
avD218_1 (SUBSUB Sub) iprobe
TO ADD: I0 (net1 net2) myblock
\#7cI1\|avD201_5 (Sub I1\|net11) nwdiode area=2.35472e-10 \
perimeter=0.00012938 dbv=0.0 m=1
\#7cI1\|avD201_4 (Sub I1\|net11) nwdiode area=6.4e-11 perimeter=3.2e-05 \
dbv=0.0 m=1
ends diode_Test_Top
// End of subcircuit definition.
  • Quek
    Quek over 8 years ago
    Hi Pietro
    I think you can do it as follows:
    a. Create a cell named "myBlock". It should have a symbol and spectre view
    b. Add the symbol view of the cell to the extracted view
    c. Select the newly created instance
    d. Go to "Connectivity->Nets->Propagate" and add the appropriate net names for each terminal of myBlock
    e. Execute the following cmds in CIW:
    cv=geGetWindowCellView()
    dbSetConnCurrent(cv)
    dbSave(cv)
    f. Netlist the extracted view. It should now include myBlock instance
    Best regards
    Quek
  • PietroUser
    PietroUser over 8 years ago in reply to Quek
    Hi Quek,
    thank you for your reply. Is it possible to do these operations with a SKILL script?
    Or by modifing the way the netlist is created?
    Best Regards,
    Pietro
  • Quek
    Quek over 8 years ago in reply to PietroUser
    Hi Pietro
    I think modifying the extracted view is most probably easier than manipulating the netlister. : )   Would you please try the following?
    procedure( CCSaddInstToExtractedView(lib cell view libM cellM viewM net1 net2 term1 term2)
        let( (cv cvm pt inst netId termId)
          cv=dbOpenCellViewByType(lib cell view "" "a")
          cvm=dbOpenCellViewByType(libM cellM viewM)
          pt=leftEdge(cv~>bBox):bottomEdge(cv~>bBox)-1
          inst=dbCreateInst(cv cvm nil pt "R0")
          foreach( (net term) list(net1 net2) list(term1 term2)
             netId=dbMakeNet(cv net)
             termId=dbFindTermByName(inst~>master term)
             dbCreateInstTerm(netId inst termId)
          ) ;foreach
          dbSave(cv)
          dbClose(cv)
          dbClose(cvm)
        ) ;let
    ) ;procedure
    E.g.
    CCSaddInstToExtractedView("A_testcase" "inv1" "av_extracted" "gpdk045" "resm1" "symbol" "aaa" "bbb" "PLUS" "MINUS")
    The above cmd will add an instance of resm1 into the av_extracted view. Nets aaa and bbb will be assigned to terminals PLUS and MINUS on resm1.
    Best regards
    Quek
  • PietroUser
    Thank you Queck. It works perfectly.
    I was wondering whether the instance statement "I0 (aaa bbb) resm1" can be included in the netlist during the creation of the netlist itself.
    Could be this possible witht the command  "nlPrintInsComments"?
    Thanks and Best Regards,
    Pietro
