  3. Filter Layout pins from LVS
  • Views 15463
PietroUser
PietroUser over 8 years ago
The LVS extract some devices with 3 pins, while in the corresponding schematic device has 2 pins.
I need to extract the third pin in the layout in order to include a customized model.
Is it possible to filter the additional pin extracted by the LVS in order to have LVS clean?
Pietro
    Please read Guidelines for the Custom IC Design Forum - you have not said which LVS tool you're using (I don't even know if it's a Cadence tool or that from someone else; even with Cadence there are several), nor which version you're using.
  • PietroUser
    PietroUser over 8 years ago in reply to Andrew Beckett
    I am using Virtuoso Layout XL of IC6.1.5-64b.500.11 .
    Pietro
    Andrew Beckett over 8 years ago in reply to PietroUser
    Pietro,
    Virtuoso Layout XL is not a LVS (layout versus schematic) tool, it's a layout tool. So that doesn't help, unfortunately...
    You might be using Diva, Dracula, Assura, PVS, Calibre, Hercules, etc etc - this is the important information. Also some indication of what the terminal is on the extraction side and what it's connected to would be useful.
