  3. Will different save options cause different Spectre simulation...
  • Subscribers 133
  • Views 1729
Will different save options cause different Spectre simulation time?
Cambridge Lv
Cambridge Lv over 8 years ago
I’m using Spectre in ADE L to run simulation. When setting ‘selected’ in ‘Select signals to output(save)’, it elapsed about 135 seconds. Setting ‘allpub’, it elapsed about 172 seconds. Of course, the larger the circuit is, the more time difference between them.
Does it make sense? In my opinion, no matter which setting I choose, the simulation should cover the whole circuit, or just result from disk I/O?
Thanks!
  • Saloni Chhabra
    Saloni Chhabra over 8 years ago
    Yes, this is expected. The simulation is always running over the whole circuit, but when you choose to save more signals, simulator needs to write additional waveform points to disk (PSF database) which will take more time.
    Saloni
  • Cambridge Lv
    Cambridge Lv over 8 years ago in reply to Saloni Chhabra
    Got it. Thanks.
